Activity › Forums › Adobe After Effects › Adjusting keyframed animation as though it were bezier curves
  • Adjusting keyframed animation as though it were bezier curves
    Posted by Scott Hathaway on June 24, 2009 at 4:41 am
    This has become troublesome lately. I’m working with an animation in After Effects that requires that I use the scale keyframe assistant “exponential scale.” This creates a series of keyframes between two keyframes in a sloping exponential curve that mimics the look of a zoom lens zooming out over very long distances. In my case I’m doing an Earth zoom, similar to what Andrew Kramer has done on his site (https://www.videocopilot.net). But in my animation I need to slow the zoom down towards the end to about half speed and I need that nice sloping exponential curve to hide the hard jump in animation speed I get when I change the ending keyframes and reapply the exponential scale keyframe assistant. Is there an expression that can manipulate keyframes thusly or should I get back to work doing it the old fashioned way? Thanks everybody
    -Scott
    Scott Hathaway replied 17 years, 3 months ago 2 Members · 2 Replies
  • Michael Szalapski
    June 24, 2009 at 8:26 am
    What version of AE are you using? Look in the documentation for information on the Graph Editor. It lets you edit keyframes using (sorta) bezier curves.
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
  • Scott Hathaway
    June 25, 2009 at 4:04 am
    I’m on CS3. I’m gonna try slowly expanding the distance between keyframes with roving keyframes and spread them out evenly over the duration of the part I want slowed.
    _________
    I make movies, not a living.
