Activity Forums Adobe After Effects Adjusting height in Dan Ebberts “Building Your Own 3D Particle Generator”
  • Adjusting height in Dan Ebberts “Building Your Own 3D Particle Generator”
    Posted by Martin Banks on October 14, 2008 at 11:51 am
    I have been using this brilliant tutorial to create a similar effect that he creates for the falling snow, however I am using a different image without the rotations, just a simple fall.
    The images I am using though are longer than his snow images, and also I have adjusted the comp size to 1024 x 768 instead of the smaller size he uses.
    The problem with adjusting the comp size is that the objects now start on screen. I have adjusted their anchor points to the base of the image but they are still on screen in my larger sized compostion.
    Being a complete novice at expressions what I would like to know is, is there a way of adjusting the Y axis position value for my images so that they start off screen?
    I tried just adjusting the Y position value which did not work, and I’m guessing that is because that is used in the expression?
    Any help on how I could get my images to start off screen would be greatly appreciated.
    Many thanks,
    Martin
    (Here is a link to his tutorial for those who are unfamiliar with it: https://library.creativecow.net/articles/ebberts_dan/particle_gen.php)
    Martin Banks replied 17 years, 10 months ago 24,811 Members · 1 Reply
  • Martin Banks
    October 14, 2008 at 12:30 pm
    I solved the problem by just moving the camera closer.
