Activity Forums Maxon Cinema 4D Adjusting Axis
  • Adjusting Axis
    Posted by Adam Zygadlo on July 21, 2011 at 3:39 pm
    Hello everyone,
    Is there a way to adjust the axis on the object, where for example: the axis starts in the corner of a cube and I want to adjust the Y only, so the end result of the axis sits in the middle of the cube at the bottom?
    I am aware of the object axis tool but is there a tool, where I click on and it will center bang on of the object and not middle of the whole object!
    Hope this makes sense.
    Cheers,
    +Z
    Adam Jozef Zygadlo
    Motion Graphic Designer
    07708 124 915
    http://www.jarbrain.com
    ‘Filled with brainy goodness.’
    Adam Zygadlo replied 15 years, 1 month ago 3 Members · 6 Replies
  • Eddy Rose
    July 21, 2011 at 4:21 pm
    I don’t believe there is any more developed way to adjust the axis beyond the object axis tool. What does center bang mean?
  • Adam Zygadlo
    July 21, 2011 at 4:26 pm
    Sorry my bad, I meant to say is there a way to make it perfect in the middle instead by manually doing it by hand, which could be off by a few pixels. Auto align to center on Y, X or Z.
    +Z
    Adam Jozef Zygadlo
    07708 124 915
  • Eddy Rose
    July 21, 2011 at 4:38 pm
    Use the Axis Tool and in the coordinates palette select Object(Rel) enter 0 for all position and rotation coordinates. That ought to do the trick.
  • Adam Zygadlo
    July 21, 2011 at 4:43 pm
    Hmmmm it will do, just wondering if there’s an option like that.
    Thank you Eddy,
    Kind regards,
    +Z
    Adam Jozef Zygadlo
    07708 124 915
  • Adam Trachtenberg
    July 21, 2011 at 8:30 pm
    Actually there is a tool that does exactly what the OP requested: the Axis Center tool (Structure>Axis Center). It does some other neat tricks, too.
  • Adam Zygadlo
    July 22, 2011 at 9:28 am
    Hey Adam,
    Well, I never noticed that feature before and yet I use the other features. Always learning new features in software which I have been using for years! lol
    Cheers fella!
    +Z
    Adam Jozef Zygadlo
    07708 124 915
