Activity › Forums › Apple Final Cut Pro Legacy › Adjusting audio
Adjusting audio
Posted by Alicia Harwell on December 12, 2007 at 5:30 pmI need to simulate a phone conversation. Does anyone know what effects I could use to make the audio sound like a realistic phone call?
Mark Pinder replied 18 years, 9 months ago 3 Members · 2 Replies -
Toby Dalsgaard
December 12, 2007 at 5:39 pmEQ
Just roll off the highs and lows and crank up the mids. That’s really what any preset parameter is doing anyway.
Mark Pinder
December 12, 2007 at 10:11 pmAs the other poster mentioned, EQ will make it sound mostly like a phone. Roll off the highs at around 4-6 KHz and the lows at around 200 Hz. push 1KHz a little too.
It also helps if you compress the heck out of the dynamic range of the audio, very low threshold and a high compression ratio. Phone systems have next to no dynamic range.
Lastly, to simulate the ‘plastic’ sound of the phone handset itself, try adding a little bit of delay in the 10-15 millisecond range. Not enough to create an actual delay effect, but just a hint of it, to simulate the sound-waves bouncing around off the plastic of the phone itself.
If all that’s too complex, just stick with the EQ…
Cheers
Mark M. Pinder
Chief Technical Engineer
Paperny Films
