Activity Forums Adobe After Effects Expressions adjusting an effect on multiple layers?
  • adjusting an effect on multiple layers?
    Posted by Daniel Connell on February 8, 2006 at 5:45 am
    I’ve got a brightness/contrast effect that I want to apply to about half a dozen layers, then animate having all layers using the same keys. I don’t want to have to do this by hand for each layer if it’s at all avoidable.
    thanks all
    Daniel.
    Scott G replied 20 years, 7 months ago 5 Members · 4 Replies
  • Mylenium
    February 8, 2006 at 6:13 am
    link them using simple pickwhip expressions.
    Mylenium
    [Pour Myl
  • Nils Palmen
    February 8, 2006 at 1:06 pm
    doesn’t an ADJUSTMENT LAYER do the trick?
    1 adj. layer above your layers – and keyframing the adjustement layer?
  • Jim Zito
    February 8, 2006 at 3:44 pm
    What about precomping them then applying the effect?
  • Scott G
    February 9, 2006 at 2:16 am
    there’s a fantastic script at http://www.aeenhancers.com that will duplicate a layer’s effects and link them back to the original layer, so if you change it on the original layer, all the “child” effects change as well. brilliant!
