Activity Forums Adobe After Effects Adjusting a frame of Rotoscope
  • Adjusting a frame of Rotoscope
    Posted by Gully Moore on October 2, 2011 at 7:20 pm
    I’ve been using the Rotobrush in CS5 which I have found fantastic!
    I did 10 seconds of footage using 1 “span” but now I’ve finished it I need to go back and just tweak a couple of the frames, but when I do it starts analyzing all the frames from the start again. How can I just tweak individual frames?
    Danielle Clement replied 14 years, 10 months ago 3 Members · 2 Replies
  • Angelo Lorenzo
    October 2, 2011 at 9:55 pm
    How much needs to be tweaked?
    I do this when using the rotobrush:
    1. I let the rotobrush run with adjustments as I go using the rotobrush tool.
    2. I freeze the rotobrush tool.
    3. I turn on quickmask (the default is a red overlay displaying the mask).
    4. I use the normal brush tool set to alpha only and per-frame and using black and white (black for mask, white to reveal) I paint my adjustments on frames that need them.
    5. On the rotobrush effect layer, I turn down all mask refinement settings to off or zero.
    6. I add the “refine mask” effect on the layer and adjust as needed. This way it refines the mask that is comprised of the rotobrush and my manual adjustments; it helps get rid of per-frame jutter from manual adjustments.
    I hope that make sense for you.
    – Angelo Lorenzo
    https://FilmsFor.Us Sell your film and connect with your audience
  • Danielle Clement
    November 12, 2011 at 6:03 pm
    I’m having issues with rotobrush propagating only part of the 15 second clip, it keeps stopping at 8 seconds and it ignores the rest. How do i get it to recognize the rest of the clip?
