Activity Forums Avid Media Composer Adjust which ‘Frame’ is used for ID in bins
  • Adjust which ‘Frame’ is used for ID in bins
    Posted by Alex Bond on June 25, 2008 at 2:17 pm
    Is it possible to change what picture appears as the Frame for clips in bins, ie when you change the view to Text, the picture on the left, currently set from the first frame of the clip.
    I need to be able to adjust this for printing bins for clients who want the frame to be useful to them (if it’s a pullout for example you won’t be able to make out what the clip is on the first frame as it could be too zoomed in)
    Thanks in advance
    A.
    Alex Bond replied 18 years, 2 months ago 3 Members · 3 Replies
  • David Braswell
    June 25, 2008 at 4:18 pm
    1-Place the bin in frame mode.
    2-Select the clip you want to adjust.
    3-Use JKL to find the frame you want to represent the clip.
    Note: There may be a setting that has to be switched to allow you to playback from the bin… I don’t think so, but if this doesn’t work go through the settings.
  • Dave Schweitzer
    June 26, 2008 at 5:42 am
    Same steps as above, but I’ve always used the 10-fr and 1-fr keys 1,2,3,4 on the alpha keyboard.
  • Alex Bond
    June 26, 2008 at 8:33 am
    Cool, thanks
