Activity Forums Adobe After Effects adjust length(time) of multiple, staggered layers together…
  • adjust length(time) of multiple, staggered layers together…
    Posted by Aza Allen on June 25, 2011 at 8:23 pm
    Sorry for the bad description, I can’t seem to find the word I need to use, BUT…
    I have a whole bunch of layers, stacked and staggered in a slide-show, basically. I want to say, take 10 or more layers, and stretch out their time equally, as if I were stretching them as a precomp… ie – NOT just selecting 10 layers and stretching them out to where they over lap, but stretching them as if they were one unit…
    Thanks all, sorry for the ignorance…
    Aza
    Make sure to check out our website http://www.makeyourfriendsuncomfortable.com and my personal website http://www.ruesterprod.com
    Laura Mccann replied 6 years, 9 months ago 4 Members · 4 Replies
  • Angie Taylor
    June 26, 2011 at 8:57 am
    Hi there,
    Select all the layers in the Timeline. Hover over the end of one of them till you see the Trim tool. Click and drag the edge of the layer and all the others will follow.
    Hope this helps 🙂
    cheers,
    Angie
    Angie Taylor animation & illustration for television, film, web and devices
    https://www.angietaylor.co.uk
    Twitter: theangietaylor
    Linkedin: theangietaylor
    https://www.facebook.com/pages/Angie-Taylor/118378194869002
  • Aza Allen
    June 26, 2011 at 7:19 pm
    Thanks for the reply Angie…
    I wish I could describe this better…. I already know about that, and now that I’m thinking about it, After Effects itself may not be able to do what I’m asking without a script, or expression.
    I am trying to stretch the clips as if they were one unit, not a bunch of separate layers who’s out points are just dragged out. Say I had 3 clips staggered so the next one’s in-point was at the out-point of the previous clip. I want to try to grab the endpoint of the 3rd clip, drag it out to stretch the time, but have the in points move with the outpoints, and all three stretch equally.
  • Qihuii Hanabi
    May 16, 2017 at 5:37 pm
    Slide your Time Indicator to the position, then press Alt+]. This will snap all the selected layers to the indicated time.
  • Laura Mccann
    November 15, 2019 at 3:10 pm
    Hi, I know this thread was from years ago, but I think I have the answer if people are searching for the same thing. If you select all of the keyframes that you want to edit, then hold “ALT” and select/drag the last keyframe of the selected, you can compress/expand all of those keyframes at once. I hope this helps.
