Activity Forums Adobe Encore DVD Adjust Encore OverCompression ? ?
  • Adjust Encore OverCompression ? ?
    Posted by Henry Panniell on November 20, 2008 at 3:18 am
    Hi
    Ihave a 1h20min project that is compressed down to approx 30% of the DVD, my transcodeing settings are 1.5-4.3 -7.5mbs. When I started out I used Encore Auto setting and the entire disk was filled but I had pauses and skips to catch up after the variou pauses. I lower the transcode setting as above but now it overcompress my project. Is there balance . . . auto setting had 9mb on the high end. How can I stop this from over compressing.
    Thanks – hap
    Joe Bowden replied 17 years, 10 months ago 2 Members · 1 Reply
  • Joe Bowden
    November 20, 2008 at 3:36 pm
    Transcoding media to exacting requirements is a bit of a black art. Especially software encoding.
    I would suggest that you keep experimenting until you find an acceptable compromise between visual quality and playback compatibility.
    For instance, try raising the minimum bit rate a bit, or raising the average bit rate a bit. Keep Quality at 4 or 5. Try reading up on MPEG-2 compression, online or in book form (DVD Demystified hs some good information). Expect to spend some time at all of this.
