Activity Forums Apple Motion Adjust Control points tool not working in 3D Space, Camera Left (Motion 4)
  • Adjust Control points tool not working in 3D Space, Camera Left (Motion 4)
    Posted by Nikko Koetsch on August 22, 2013 at 4:34 pm
    Hi there,
    I am trying to create a 3D Spiral in motion and so far I have made three circle outlines stacked over each other with gaps in-between with local 3D and facing camera checked. I am trying to adjust one control point on each circle to go up (along the y axis?) and attach to the circle above to make the spiral. When I go to the left camera and try to lift the control point I want to attach to the circle above up it wont let me grab the point with the adjust control points tool, I believe this is because I created the circles on a different plane? How can I fix this or is there an easier way to do this?
    Nikko
    Andy Neil replied 13 years ago 3 Members · 2 Replies
  • Mark Spencer
    August 22, 2013 at 4:44 pm
    Shape control points only have X and Y coordinates – as you can see in the Shape Inspector. In other words, shapes are always on 2D planes.
    For a spiral motion you can use a Motion Path behavior – the control points for it can be moved in X, Y, and Z.
    Mark Spencer
    Freelance Producer/Editor/Motion Graphics Artist
    Apple-certified Master Trainer
    Author, Motion 4 from Peachpit Press
    https://www.applemotion.net
  • Andy Neil
    August 22, 2013 at 5:36 pm
    Man, wouldn’t it be great to have at least 3D oulines? Just make fill unavailable and let us place bezier points in 3D space. I’m probably overlooking something which makes it impossible, but a guy can dream can’t he?
    Andy
    https://www.timesavertutorials.com
