Activity Forums Adobe Premiere Pro adjust aspect ratio of a clip
  • adjust aspect ratio of a clip
    Posted by Chris Franklin on February 15, 2011 at 6:28 pm
    Hello,
    I’m editing on Premiere Pro CS4 and I’m trying to change the aspect ratio of a clip. I usually edit in Sony Vegas and in Vegas, all you have to do is click the Pan/Crop button and at the top of the Pan/Crop window, you can choose which aspect ratio you want your video clip to be (4:3, 16:9, etc.).
    How do I change the aspect ratio of a clip?
    Chris Franklin replied 15 years, 6 months ago 2 Members · 2 Replies
  • Kelsi-dean Buck
    February 16, 2011 at 11:51 am
    You can do this a few ways. but the quickest and easiest is probably…
    Add a ‘motion’ effect to the clip.
    go into the effects settings and ‘distort’ the clip to your desired ratio from there.
    You can also of course choose the project’s ratio standard when starting a new project.
  • Chris Franklin
    February 16, 2011 at 6:19 pm
    Thanks….I’ll try it
