Activity › Forums › Apple Final Cut Pro Legacy › Additonal Audio Transitions?
  • Additonal Audio Transitions?
    Posted by Bryon Daniels on May 14, 2010 at 1:44 am
    I’ve been looking around and I’m not having any luck. Are there any extra audio transitions other than the obvious cross fades. I’m not sure if they have released anything like that either through apple or a third party. If you can give me any info that would be great.
    I’m basically looking for something to distort two tracks of audio while blending them together or anything along those lines. I’m sure you get what I’m going for.
    Arnie Schlissel replied 16 years, 4 months ago 2 Members · 1 Reply
  • Arnie Schlissel
    May 14, 2010 at 3:21 pm
    You would be better off doing this in Soundtrack Pro, but you may need to add some 3rd party audio filters to do it. There are no packages of “audio transitions” per se, but you can build your own by cranking the effect (probably by routing your signal through a bus) up & down as you go in & out of the transition.
    Arnie
    Post production is not an afterthought!
    https://www.arniepix.com/
