Activity Forums Adobe Premiere Pro Additional Second in Output File
  • Additional Second in Output File
    Posted by Can Adil on April 28, 2017 at 3:13 pm
    I have a 30:00 minute sequence. It is exactly 30 minutes and 00 seconds.
    When I export it in Premiere Pro, the output file is 30:01 in length. It has 1 extra seconds!
    I checked for solutions, but couldn’t find anything better than fixing my sequence to 29:59, which then ends up in 30:00.
    What can be the reason for the additional second?
    My sequence is 24fps, and the export is 25fps, and I may only assume this can be a reason.
    Any idea?
    Can Adil replied 9 years, 4 months ago 1 Member · 1 Reply
  • Can Adil
    April 30, 2017 at 5:40 am
    I simply changed the fps in the export settings. Premiere manages it quite well, but takes some more time.
    The files I have are all in 24fps.
    I needed the output both in 24 and 25 fps, for submission requirements.
