Activity Forums Apple OS X additional monitor
  • additional monitor
    Posted by Maxims Zima on April 16, 2009 at 2:36 pm
    I want to use a flat screen tv for additional monitor on my imac. When i hook up with the mini dvi to vga, then vga cable to flat screen i get a no signal message. Any one got a suggestion, or is this a possibility?
    Trent Whittington replied 17 years, 4 months ago 3 Members · 2 Replies
  • Jordan Wolf
    April 19, 2009 at 1:18 am
    Make sure the television is set to the correct input (“VGA” or “Computer” would be my guess).
    If that’s not it, then you might want to try this:
    1. Connect the VGA-MiniDVI adapter to the VGA cable.
    2. With both the computer AND television powered OFF, plug the adapter into the MiniDVI slot.
    3. Power on the television.
    4. Power on the computer.
    Sometimes Macs have trouble sensing an external display if they are already on.
    Wolf
  • Trent Whittington
    April 25, 2009 at 5:37 pm
    You may also want to check the television specifications and see what resolution it supports over VGA. With my iMac I have a 32inch 1080p television plugged in via mini dvi-vga but my television will only accept 1024×768 through VGA, however if I get mini dvi-hdmi it will accept the full 1080.
    Just another useful thing to keep in mind.
    Trent Whittington – Currently studying Associate Degree in Digital Television
    iMac – 24inch 3.06Ghz, FC STUDIO 2, Adobe Production Premium CS4.
    Asus eee – 8.9inch 1.6Ghz 1Gb Ram, Windows XP
