Activity Forums Apple OS X additional battery/alt. use of desktop monitor
  • additional battery/alt. use of desktop monitor
    Posted by Saya Hillman on April 19, 2009 at 2:40 pm
    Hi there, two inquiries if anyone can help –
    1. My mother finally retired her iMAC from five years ago for a MacBook (March ’08). She misses the size/quality of the iMAC screen though. Is there a way to hook up the desktop to the laptop so that she can use the desktop’s screen? Or does she have to purchase an external monitor? If the latter, any tips/links on what to look for in ext. monitors would be much appreciated!
    2. I’d like to get an external battery for my MBP (March ’08), and see that there are a lot of options out there. Anyone have any recommendations or links to share on the topic?
    Thanks a million,
    April
    MAC OSX 10.5.6
    1.8 GHz Power PC iMAC G5
    768 MB DDR SDRAM
    MAC OSX 10.5.2
    2.4 GHz Intel Core 2 Duo MacBookPro
    2 GB MHz DDR2 SDRAM
    LaCie d2 Extreme 160GB 7200 RPM 8MB Buffer
    LaCie Big Disk 380GB
    FCP 6.0.5
    David Hall replied 17 years, 4 months ago 2 Members · 1 Reply
  • David Hall
    May 21, 2009 at 8:01 pm
    April, the only way I know of to use an imac as an external would be to connect the macbook pro via firewire, put the MBP into target mode, and option boot into the imac. The problem with this is she’ll be using the processor, RAM, etc. of the iMac and not the MBP. Same goes with using the Screen Sharing Utility.
    Best suggestion would be to sell the iMac and use the money to offset the cost of a new monitor. Unless your mother is doing video editing or high end gaming, any standard DVI monitor should do fine. I’ve been using a Viewsonic 20″ LCD at work for a while now and its been working great. Usually go for around $200ish.
    David Hall
    Service Manager
    Zero One Media Center
    Apple Certified Hardware Technician
