Activity Forums Adobe Premiere Pro addio mixing deck
  • addio mixing deck
    Posted by Neil Bradley on August 28, 2007 at 7:39 pm
    Has anyone heard of a physical mixing deck that connects to Premier? The mixing deck in Premier is excelent however the user can only adjust one track at a time. With a physical deck you could fade in and fade out as many tracks as your fingers could handle.
    I wondered if there was such a dvice out there.
    Neil
    Blast1 replied 19 years ago 3 Members · 6 Replies
  • Blast1
    August 29, 2007 at 2:25 am
    There are controllers like you mention, J L Cooper makes them,
    Behringer, etc. The problem is patching the generic software for use, Its nicer to have things preprogramed.
    https://www.jlcooper.com/pages/es8100.html
    I have EdiusPro v4.5 which has the capability of using this controller, https://www.behringer.com/BCF2000/index.cfm?lang=eng
    When Ihave some spare time(hysterical laughter) I was going to try setting it up with Ppro
  • Neil Bradley
    August 31, 2007 at 4:25 am
    Thats a very nice piece of hard ware and the price is ok too.
    I take it its connected via fire wire?
  • Bart Straman
    September 2, 2007 at 7:28 pm
    that’s what i wanna know to, how do you connect it to your pc and synchronize it with premiere pro?
    I have used 2 dj decks(pioneer cd decks) with a behringer mixer, but there are sure no firewire ports on it.
    only tulp(red and white heads. you know) or 3.5mm jack
    thanxs
    Bart
  • Bart Straman
    September 2, 2007 at 7:34 pm
    oohw, just reading the features of that device in your url.
    B-CONTROL FADER BCF2000
    is that specialy made for this kinde software? easy plugin by USB. hmmm. should be easy 🙂
    thanxs anyway
    Bart
  • Blast1
    September 3, 2007 at 2:34 am
    The control surfaces are made for use by different kinds of software, the data/presets that comes with it or you can download presets and programing aids, I’ve used it with Cubase, and its supposed to work with Edius 4.5x which was setup by GrassValley for it, but I haven’t had time to play with it.
    Best thing to do is download and read the mamuals and guides
    Also put in a request to Adobe to program use for one of the available control surfaces, it should be made available for Audition, Premiere, etc
  • Blast1
    September 3, 2007 at 5:18 am
    My bad, Audition 2 is supposed to support BFC2000, earlier versions didn’t
