Activity Forums Adobe After Effects Expressions Adding Wiggle to Dan Ebbert’s Keyframe Overshoot Expression
  • Adding Wiggle to Dan Ebbert’s Keyframe Overshoot Expression
    Posted by Matt Chandronait on June 30, 2021 at 5:13 am
    How to make the property (in my case, position) wiggle? I’ve got a few hundred layers with two keyframes in the position property, all with Dan Ebbert’s expression applied. I want each layer to be wiggling after it has settled (kind of like something zooming through water and then coming to a sudden halt and then drifting around lightly).
    Thinking about it, the movement between the two keyframes for the layers in my comp are so quick that it doesn’t need to wiggle AFTER it has settled. The position value can be wiggling the whole time because no one will notice it while the layers are moving in my comp. Basically, it’s like I need two expressions: the Keyframe Overshoot expression and a Wiggle applied at the same time, but I just don’t know enough to make them play together.
    In the past I’ve solved this problem in a less-elegant way by simply creating a null as a parent and then putting the wiggle on the parent, but in this particular comp I’m dealing with hundreds of layers and would rather just apply an expression to each one’s position property. Here’s in Dan’s code in case you’re not familiar with it already from his site (https://www.motionscript.com/articles/bounce-and-overshoot.html). How do I get a wiggle in there?
    freq = 3;
    decay = 5;
    n = 0;
    if (numKeys > 0){
      n = nearestKey(time).index;
      if (key(n).time > time) n--;
    if (n > 0){
      t = time - key(n).time;
      amp = velocityAtTime(key(n).time - .001);
      w = freq*Math.PI*2;
      value + amp*(Math.sin(t*w)/Math.exp(decay*t)/w);
    }else
      value
    Matt Chandronait replied 5 years, 2 months ago 2 Members · 4 Replies
  • Andrei Popa
    June 30, 2021 at 7:20 am
    I think you can replace the “value” with “wiggle(1,100)”.
  • Matt Chandronait
    June 30, 2021 at 5:08 pm
    At first I thought the same, but that doesn’t seem to work. I’m pretty sure the part in the “if” and not the part in the “else” is in control for the rest of the comp’s timeline. For example, if I replace “value + amp*(Mat.sin(t*w)/Math.exp(decay*t)/w)” with “wiggle (1,100)” then the layer does indeed wiggle, but it doesn’t overshoot. Which makes sense of course because I’ve removed the line of code that actually affects the values during the overshoot, but I mean it just as an example of which part of the code is controlling the position value after the second keyframe–if any of that makes sense :). I tried adding a “wiggle (1,100)” in there so that it looks like this:
    if (n > 0){
    w = freq*Math.PI*2;
    wiggle(1,100);
    But of course that doesn’t work, either, since wiggle subsumes the rest of the script.
  • Andrei Popa
    June 30, 2021 at 10:33 pm
    I meant only replace value with wiggle. Like this:
    freq = 3;
    decay = 5;
    n = 0;
    if (numKeys > 0){
    if (n > 0){
      w = freq*Math.PI*2;
      wiggle(1,100) + amp*(Math.sin(t*w)/Math.exp(decay*t)/w);
    }else wiggle(1,100)
  • Matt Chandronait
    July 1, 2021 at 12:23 am
    OH! You meant in BOTH spots. I get it now! Thank you, worked like a charm. I appreciate you taking the time to help me out Andrei 🙂
