Activity Forums Apple Final Cut Pro Legacy Adding Watermark Through Compressor
  • Adding Watermark Through Compressor
    Posted by Greg Burke on June 1, 2011 at 8:46 pm
    IS there a way to add a watermark while sending files though COMPRESSOR? I ask because I have to Export Multiple videos in 3 formats HD, SD and HD w/a watermark (in the hundreds) and Dont wanna have to go into FInal Cut And Put it in manually over 100 times. Any Suggestions? Thanks.
    Amy Taylor replied 13 years, 1 month ago 4 Members · 4 Replies
  • Shane Ross
    June 1, 2011 at 9:01 pm
    Yes. In the INSPECTOR in Compressor, there is a tab for FILTERS. WATERMARK is one of those filters. Select that, then select the graphic to be used as the water mark.
    BINGO was his name-o.
    Shane
  • Greg Burke
    June 1, 2011 at 9:06 pm
    OMG YOUR AMAZING MR ROSS!!!!! Thank you! IM not on my edit machine right now (on my iphone), is there a way to Control where the Graphic is placed? and How big it is?
  • Cody Walters
    June 1, 2011 at 9:40 pm
    Greg,
    Once you check the Watermark filter, you will see a Position drop down (center, lower left, lower right, etc.), scale by parameter and alpha parameter.
    Cody Walters
    JW Studio LLC
    Houston Video Production
    Houston Wedding Videographer
    Final Cut Studio 3
    Adobe CS5 Master Suite
    Panasonic HVX-200
    Canon 7D
  • Amy Taylor
    July 24, 2013 at 5:26 pm
    Here’s a related question — How do I add a watermark/logo using compressor 4 settings through FCPX? When I compress the video in compressor, the watermark shows up fine. But when I do it in FCPX using compressor settings, it doesnt do anything.
