Activity › Forums › Avid Media Composer › Adding Volume Keyframe on Multiple Clips
Posted by Chih Steeple on April 22, 2018 at 9:05 pmDear all,
I tried to find the answer online but did not have any luck. Is there a way to add volume keyframe on multiple clips in timeline? I know how to adjust all the keyframes at one time but have been adding keyframe one by one to each clip. Thanks a lot.
Sincerely,
Chih
Scott Thomas replied 7 years, 1 month ago 6 Members · 10 Replies -
Job Ter burg
April 23, 2018 at 8:54 amWith the Audio Mixer in Auto mode, gang channel faders, move one fader.
Juris Eksts
April 23, 2018 at 9:10 amIf you have all the tracks selected, hitting the key frame button will mark all the tracks in the same place.
If you have an ‘In’ and an ‘out’ around a number marks, then moving one of the marks up or down will move all the marks. -
Chih Steeple
April 23, 2018 at 4:28 pmThank you both for the tips. I guess I did not explain the question correctly. I meant to say if there is a way to add keyframe to multiple clips on the same track not different tracks. I chopped the interview already but now would like to adjust the volume using keyframe. Many thanks again.
Chih
Shane Ross
April 23, 2018 at 6:14 pmKeyframes on the SAME track? Yes…add keyframes to all the clips you want to lower…then mark IN and OUT to the section you want to adjust, grab one keyframe, ALL will highlight, and then raise or lower. Job mentioned this in his response.
You can also LASSO those keyframes and adjust. Just make sure not to lasso the full clips, but just the keyframes, otherwise you’ll go into TRIM mode on the cut points.
Shane
Little Frog Post
Read my blog, Little Frog in High Def -
Chih Steeple
April 23, 2018 at 9:39 pmHi Shane,
Thank you for the response. But I meant to ask to add keyframes to all the clips not to adjust them. Say I have 30 clips from the same interview. Now I need to add keyframes one by one to all 30 before I can adjust the volume at one time. I was wondering if there is a way to add keyframes to all 30 clips at one time?
Very best,
Chih
Job Ter burg
April 23, 2018 at 11:08 pmDon’t do this with keyframes. Mark in-out around the clips you need to increase/decrease, set your Audio Mixer to Clip mode, set the level for the current clip, then choose ‘Set Clip Level In-Out’ from the Audio Mixer’s hamburger menu. You can still add keyframes or use automation gain on top of these clip levels.
Chih Steeple
April 24, 2018 at 2:00 amHi Job ter Burg,
Your method is definitely the right way to go. However, the interview volume is so low that after I increased the gain to +12db, I still could barely hear the sound. That was why I thought I would use the keyframes to bump it up even more. But thank you very much for sharing.
Warmly,
Chih
Nick Griffin
April 25, 2018 at 9:31 pmNot addressing your original question (which was answered quite well by the way), but rather what you just mentioned about +12 not being enough gain, here’s a simple solution.
On a project a couple of years ago we were using an out of town shooter for interviews who may know something about visuals but NOTHING about sound. Everything he provided was over 36db too low.
The solution is to get the first track that comes synched with the video where you want it to be in terms of timing. Then copy, paste and ALIGN copies of just the audio track on additional blank tracks added below. Then -36db can be brought to a decent level just by sending two, three or even four channels of the same audio to the same place in the mix. i.e..- center for an interview.
The only negative here is that you are also raising the noise floor of the recording. Fortunately with modern equipment the noise floor is typically so low that it shouldn’t be much of an issue.
Hope this helps.
Job Ter burg
April 25, 2018 at 10:09 pmHow about adding either the Gain plugin or a compressor from the Channel Strip plugin?
Scott Thomas
July 19, 2019 at 12:30 pmSorry to disagree with one of the responses but the original question has not been answered and I would like to find a way of doing this:
You inherit a sequence of audio cuts (segments) and want to use the audio keyframe / rubber band method of mixing. I want to put a single keyframe in the middle of each segment which I can then adjust within each segment or lasso multiple keyframes and adjust them as a group.
It seems that once a clip has been cut into segments there is no way of adding a keyframe to all the segments without clicking on each segment and manually adding them.
What I want is an option on the Audio Mixer fast menu that is “Add Volume Automation on track In-Out” .
