Activity Forums VEGAS Pro Adding video to time line from trimmer without audio track
  • Adding video to time line from trimmer without audio track
    Posted by Mark Krueger on November 28, 2011 at 9:02 pm
    I am working with some media that I would like to add to the timeline without adding the audio. Video only.
    How is that done?
    Mark Krueger replied 14 years, 9 months ago 2 Members · 2 Replies
  • Matt Crowley
    November 28, 2011 at 9:18 pm
    You can right-drag (drag with right mouse button) from the Explorer to the timeline, then select Video Only>Add Video Across Time. The same can be done for audio only.
    You can also add video only (or audio only) from the trimmer. When you create your selection in the trimmer, drag above the upper dotted horizontal line (top edge of the video) to select video only, or below the lower dotted line to grab audio only.
    If you’ve already made a trimmer selection, hit Tab to cycle between audio only, video only, or both. Then drag the selection to the timeline.
  • Mark Krueger
    November 29, 2011 at 10:57 am
    Thanks Matt!
