Activity Forums Maxon Cinema 4D adding video on a plane to a scene
  • adding video on a plane to a scene
    Posted by Paulie Notaro on October 23, 2009 at 5:37 am
    hi when i add video on a plane to a scene with other objects and render, it renders ok but when i hit the play button after 20 frames or so everything disappears and if i take my video out of the scene and hit play everything works am i doing something wrong is my resolution on my video to high i have 1280 by 720,please i can’t figure this out
    Adam Trachtenberg replied 16 years, 11 months ago 2 Members · 1 Reply
  • Adam Trachtenberg
    October 23, 2009 at 3:39 pm
    Cinema will automatically change the display mode in the viewport if the frame rate drops too low. The video is probably causing that to happen. You can generally speed up playback by using image sequences instead of compiled movie files. That way Cinema doesn’t have to decompress every frame.
