Activity Forums Apple Final Cut Pro Adding transition to clip/text later
  • Adding transition to clip/text later
    Posted by Ben Lithman on December 12, 2020 at 1:47 pm
    Hi, sorry if this is a stupid question…. But how do you STOP FCPX adding a transition (let’s say a simple crossfade) to the start of a clip when dragging it and dropping it ONLY to the end of a clip??
    Evan Fitzer replied 5 years, 9 months ago 3 Members · 3 Replies
  • Patrick Donegan
    December 15, 2020 at 9:54 pm
    Strange.
    I have never noticed and transition being added auto mataclly in FCP X.
    What version is it?
    please post a screen shot.
    are you sure this is not iMovie?
  • Ben Lithman
    December 16, 2020 at 10:22 am
    Are you seriously saying I don’t know the difference between iMovie and FCPX?
    see attached.
  • Evan Fitzer
    December 16, 2020 at 7:03 pm
    Hi Ben:
    I watched your vid. In fact, you are dragging the effect onto the ‘entire clip’ and and so the effect/transiton is applied to both ends simultaneously, this is how FCPX functions. To get the desired result you’re looking for, select either the head or tail of your clip and then double-click your effect/transition, in this case the dissolve, and it will append the ‘dissolve’ only to that particular end of the clip. At least that’s how I do it.
    Cheers,
    Evan
