Activity › Forums › Apple Motion › Adding Tracker in Match Move?
  • Adding Tracker in Match Move?
    Posted by Grant Gomm on June 15, 2011 at 4:29 pm
    I’m trying to get a mask to match up with a layer in a different group, but it’s a little off. I hoped to add a tracker or two to see if that would match it better. I thought I remembered that there was a way to have multiple trackers with the Match Move behavior. But either I was wrong or I’m overlooking something. Is this possible, and if so, could someone direct me in the right path? Thanks in advance.
    -Grant Gomm
    http://www.blacklionproductions.com
    Grant Gomm replied 15 years, 3 months ago 2 Members · 2 Replies
  • Simon Ubsdell
    June 17, 2011 at 10:39 am
    If you change the Match Move’s “Adjust” option to “Scale” or “Rotation” (in the Behaviors tab) you’ll get a second tracker.
    Or better still, if you change the “Type” from “Transformation” to Four Corners you’ll get four trackers that will enable you to corner pin if that’s what you need.
    Hope that helps.
    Simon Ubsdell
    Director/Editor/Writer
    http://www.tokyo-uk.com
  • Grant Gomm
    June 17, 2011 at 4:19 pm
    Thanks Simon. I appreciate the help!
    -Grant Gomm
