Activity Forums Adobe After Effects Adding to multiple shape layers simulataneously
  • Adding to multiple shape layers simulataneously
    Posted by Chris Beaton on May 26, 2021 at 7:13 am
    I was just wondering if there was a way to add for example an ellipse to multiple After Effects layers at the same time rather than having to do it to each individual layer separately?
    Also is there a shortcut to open up transformations within the content of shape layers similar to the P, S, T, R for normal layers, if anyone knows how to do this it would be hugely helpful.
    Many thanks
    Chris
    Graham Quince replied 5 years, 3 months ago 2 Members · 1 Reply
  • Graham Quince
    May 29, 2021 at 10:20 am
    You could take your comp and place it in another comp to apply the mask to it or you couuld try adding an adjustment layer, adding the mask and then the CC Image Wipe and setting the completion to 100%.
    And shape layer content transform tools, not that I know of, but now you’ve suggested it, I really what that option!
