Activity Forums VEGAS Pro adding to finished project in vegas
  • adding to finished project in vegas
    Posted by Herr on June 1, 2005 at 3:53 pm
    It is probably a question that is asked quite a bit,and I have looked over the manual,but,I am still having difficulty adding new media in between events already on the timeline without having to move everything individually. Could anyone give me some good instructions on how to do this? Thanks for your help, John
    Edward Troxel replied 21 years, 3 months ago 2 Members · 4 Replies
  • Edward Troxel
    June 1, 2005 at 4:08 pm
    Several options:
    1) Ripple Edit (must be very careful with this one)
    2) Insert – Time to insert the length needed for the new material.
    3) Select all events necessary an move them all at once. I simplify this task by using the “Select Events” tool in Excalibur.
    Edward Troxel
    JETDV Scripts
  • Herr
    June 1, 2005 at 4:32 pm
    thanks ed
  • Herr
    June 2, 2005 at 1:07 am
    What is the step by step of adding fotage using ripple edit? thanks, john
  • Edward Troxel
    June 2, 2005 at 2:20 am
    Change the ripple mode to ripple everything, turn ripple ON, and drop the new clip where you want it to be. Everything after that point will be shifted to the right.
    Edward Troxel
    JETDV Scripts
