Activity Forums VEGAS Pro Adding time code question
  • Adding time code question
    Posted by Terry Esslinger on March 16, 2007 at 10:12 pm
    I am capturing video from 8mm film in one long event (full 50 ft reel, full 400 ft reel etc). The client wants a window dub (time code) to make an EDL for me to rearrange the segments. The camera is not really taping the film, the optics are just transferring it to the computer which captures 8 frames of film per second. Another program then puts the ‘avi stills’ back together as a movie and at the correct speed. Where could a window dub be placed in this process and how?
    Jerry Waters replied 19 years, 6 months ago 5 Members · 5 Replies
  • Peter Wright
    March 17, 2007 at 12:43 am
    Does the movie you finish up with after the “avi stills” are put back together have newly generated time code?
    If so, applying the Time Code FX to each clip in Project Media (Right Click / Media FX) will put this time code onscreen.
    Peter Wright
    Perth, Western Oz
    http://www.allroundvision.com.au
  • Kim Nance
    March 17, 2007 at 1:06 am
    Applying timecode to each clip will give you a whole bunch of clips all beginning at 00:00:00:00. A better option might be to throw them all on a timeline, add a new track above, insert and empty event and stretch it to the same duration as all your clips combined, and then add the timecode to this empty event. I often do this when faced with the need to supply clients with a window dub of their footage that contains timecode breaks.
    Regards
    Kim Nance
  • Gary Kleiner
    March 17, 2007 at 2:53 am
    As Peter correctly points out, adding timecode to the media in the Project Media tab will display the correct timecode for any part of the media whereever it is on the timeline assuming the timecode meta data is embedded.
    Gary Kleiner
    Vegas Training and Tools.com
    Learn Vegas and DVD Architect
    http://www.VegasTrainingAndTools.com
  • Peter Wright
    March 17, 2007 at 6:46 am
    That’s fine, Kim, but it only gives a reference relative to that particular arrangement on the timeline. By using media t/c it is there in the clip wherever it is used, and if different clips need differentiating, you can always add a superimposed “Tape 1″, Tape 2” etc or similar.
    Peter Wright
    Perth, Western Oz
  • Jerry Waters
    March 18, 2007 at 2:59 pm
    I like adding a generated text event as the top line, stretching it over the project and putting the timecode there. Then I can turn it off and on by just turning off that track.
    JerryW
