Activity Forums Adobe After Effects Adding texture colour to frames drawn in photoshop, animation
  • Adding texture colour to frames drawn in photoshop, animation
    Posted by May Kindred-boothby on February 17, 2017 at 10:53 am
    Hi, so i’ve drawn a load of frames in photoshop, they’re just limple line drawings, i’ve exported them all as png’s and imported the sequence into after effects.
    What i now want to do is fill each section the drawing with a different watercolour block texture, but that will follow the movement on to other frames. I’ve got the coloured blocks as seperate layers, but i can’t work out how to create a mask so that each block is only showing the section that i want it to. I presume there is a way to do this with masks? Can anyone help?
    May Kindred-boothby replied 9 years, 7 months ago 1 Member · 1 Reply
  • May Kindred-boothby
    February 17, 2017 at 6:26 pm
    It will animate in that it will follow the animated shapes that i’ve already drawn. In the same way that the fill tool does! Theres no easy cheat? I was so sure there would be!
