  • Posted by Nick Solsman on November 15, 2008 at 5:50 am
    Hi. I’m using Final Cut Pro 6.0, and I was wondering how to put text on a blank background. The screen is blank, due to lack of footage in this segment, and I wasn’t sure if I needed to add “blank footage” media to the project. I am also interested in adding text over regular footage as well. Any help would be appreciated
    Nick
    Bill Dewald replied 17 years, 10 months ago 4 Members · 3 Replies
  • Hector Berrebi
    November 15, 2008 at 8:07 am
    nick…
    there are many ways to do what you ask for, however, it sounds to me that what you really need is some basic fcp training, online tutorial? a book? the fcp manual? the fcp tutorial? there are many options to choose from.
    for now. in your viewer window (the left one) on the bottom right you have a little drop menu (2 actually use the right one) inside choose text, then again text. in the control tab type whatever you want, then drag the clip to your bin and edit it anywhere you want in your timeline.
    again, there are many ways, some will get you better results…
    peace.
  • Jerry Hofmann
    November 15, 2008 at 1:17 pm
    You needn’t put anything under the text as long as you want it to be over black as the background.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO, CD’s
  • Bill Dewald
    November 15, 2008 at 5:27 pm
    And, if you want a keyboard shortcut – CTRL-X makes a new Text element in the Viewer.
