Activity Forums Apple Final Cut Pro Legacy ADDING TEXT TO MOTION PICTURE
  • ADDING TEXT TO MOTION PICTURE
    Posted by Anna Panetta on January 5, 2006 at 12:05 pm
    Hi There,
    Was wondering if someone can enlighten me on the following. I am not sure if it can be done, but nevertheless, i though i would ask anyway. I am using FCP5 and have some dv footage of my son in a running race. What I’d like to do is have is name above his head and the text to follow him. Can this be done?
    ta
    anna
    Jerry Hofmann replied 20 years, 8 months ago 5 Members · 5 Replies
  • Jerry Hofmann
    January 5, 2006 at 2:13 pm
    Sure. Just create the text with your text tool or Title 3D, then use the motion tab of that clip once place in the timeline window to change it’s center position if need be over time. Keyframing the center parameter will move the text anywhere you want, when you want.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • David Bogie
    January 5, 2006 at 3:49 pm
    OR CHECK THE SAME THREAD ANNA STARTED OVER IN THE MOTION FORUM
    BOGIESAN
  • Kevin Monahan
    January 5, 2006 at 8:53 pm
    If you’d like to do it the way they do in a NasCar race, you’ll need motion tracking. Look for the plug in by Lyric.
    Kevin Monahan
    Take My FCP Master’s Seminar!
    fcpworld.com
  • Jon Burns
    January 12, 2006 at 8:27 pm
    Jerry–
    Is this the same Jerry that lived in Denver as an Avid Whiz a few years back?
  • Jerry Hofmann
    January 12, 2006 at 9:19 pm
    Yeah… still living in the Denver area…
    Jerry
