Activity Forums Adobe Premiere Pro Adding Text to an existing MOGRT
  • Adding Text to an existing MOGRT
    Posted by Martin Gardiner on June 12, 2019 at 3:35 pm
    Hi
    I made a MOGRT in AE, but because AE doesn’t allow you to add leading as a property to a MOGRT I’m trying to find workarounds.
    Can you install the MOGRT in PR and then add text in that program and resave it as a MOGRT template, so that all text properties are editable?
    Martin Gardiner replied 7 years, 2 months ago 2 Members · 2 Replies
  • John Heiser
    June 14, 2019 at 3:38 pm
    My understanding of MOGRTs is that, while both are used in Essential Graphics, the ones created in AE are different from the ones created in PP. I know you can open a MOGRT in AE, edit it and resave it, but I’m pretty sure once it’s in Essential Graphics in Premiere, it’s wrapped up.
    As for adjusting leading in your MOGRT, you might try adding the Increase Tracking effect to your text layer, delete all keyframes, then add a Slider Control and parent the Tracking Amount to the Slider. That Slider can now be added to your controls in Essential Graphics.
    John Heiser
    Senior Editor
    o2 ideas – Birmingham, AL
    iMac Retina 5k, 27-inch, 2017
    4.2 GHz i7, 32GB RAM, Radeon Pro 580 8GB
    G-Speed Studio TB-2 12TB RAID-5
  • Martin Gardiner
    June 14, 2019 at 9:14 pm
    That worked great, thanks!
