Activity › Forums › Apple Final Cut Pro Legacy › Adding text in Final Cut affects Video
Posted by Tim King on January 12, 2009 at 12:08 pmHi, a first time post.
I’m having a problem with moire/boiling in the clip that I’m posting. Adding text causes the image in the computer screen in the clip to boil, although as you can see in the following clip, no text layer, no boil.
It would be interesting to know if anyone else has come across this problem, and if anyone has a solution.
Kevin Monahan replied 17 years, 8 months ago 3 Members · 5 Replies -
David Bogie
January 12, 2009 at 3:39 pmYou forgot to copy and paste the URL tag form the upload screen.
Moiré is a specific visual artifact caused by conflicts in pixel/scanning frequency ratios; never hear of boiling.
You will need to provide some basic information like the format and codec in which you are working. Most boiling issues are simple user errors such as not viewing the resulting renders on a the release medium display or attempting to use typefaces that are inappropriate for the release medium.bogiesan
Tim King
January 12, 2009 at 4:07 pmSorry, this is my first posting, so my query was in moderation, and I was unable to post the video.
We’re working with Uncompressed 10 Bit Blackmagic. PAL 16:9 Full Height Aspect. If you can see the video, you’ll see a shimmer on the computer screen behind the meerkat, when there is text applied to the footage. In the second half of the clip, there’s no shimmer. The shimmer is not caused visually by the text, as it’s on a different part of the screen.
Kevin Monahan
January 12, 2009 at 5:29 pmDid you render it? Are you viewing it on a broadcast monitor?
Kevin Monahan
http://www.fcpworld.com
Author – Motion Graphics and Effects in Final Cut Pro -
Tim King
January 12, 2009 at 5:54 pmYes its rendered, and yes it’s being viewed on a broadcast monitor.
Kevin Monahan
January 13, 2009 at 6:02 pmText should be placed using the point controls in the Controls Tab but most people do not do that. They mistakenly move the Wireframe, which, if not careful, can cause a field reversal making the text look muddy. Did you move the Wireframe in the Motion Tab? If so, is the Y value a whole, even number? Make sure that it is.
Kevin Monahan
