Activity Forums Maxon Cinema 4D adding terain to a sphere
  • adding terain to a sphere
    Posted by Lars Wikstrom on January 24, 2007 at 8:25 am
    Hi, I am creating a globe, the kind that you see in corners of rooms or on desks. I created a sphere and added my texture to it. It looks ok but I want to add that bump to it that you see some globes have. What is the best way of doing this? I added terain to the model adn added it to the as a child so it shares the map but I want the terain to curve around to globe and look natural.
    looking for some out of the box thinking.
    -Lars
    Lars Wikstrom replied 19 years, 8 months ago 3 Members · 8 Replies
  • 8 Replies
  • Brian Jones
    January 24, 2007 at 2:39 pm
    Displacement channel in the material is a way
  • Lars Wikstrom
    January 24, 2007 at 5:49 pm
    Huh, I knew I came to the right place. I am guessing that the displacment map is a grey scale that I paint in Photoshop then?
    -Lars
  • Mylenium
    January 24, 2007 at 6:58 pm
    yupp. And you need Advanced Render for it to look decent (subpixel displacement).
    Mylenium
    [Pour Myl
  • Brian Jones
    January 24, 2007 at 9:47 pm
    or subdivide the sphere like crazy if you don’t have it (memory/speed hit)
  • Lars Wikstrom
    January 25, 2007 at 12:46 am
    I can’t seem to get it to work. I went into Photoshop and painted in the areas that I wanted raised. I painted onto a seperate file that was the same size and in grey scale. I loaded that into the texture in the Displacement. The little priview that I have for the texture shows the raised areas but when I apply it to the sphere nothing happens, it is still smooth. What am I doing wrong?
    Also I do not have advanced render. So should I change my sphere which is now 100mm and 48 segments to like 100 segments, is that how you sub divided?
    -Lars
  • Lars Wikstrom
    January 25, 2007 at 3:03 am
    Huh, I got it to work when I applied the texture to a flat plane. But it when it is on a sphere I can’t get it to work. Is there something that you need to do to add this to a sphere?
    -Lars
  • Brian Jones
    January 25, 2007 at 3:04 am
    displacement only works with poly objects so you have to make the sphere editable.
    more segments is subdividing, yes. You can also put the sphere in a HyperNurb so extra subdivision happens at render time. You can subdivide before render, at render time or a combo….
  • Lars Wikstrom
    January 25, 2007 at 4:08 am
    That was it!!! Thank you. As soon as I made it editable and rendered it it showed up.
    Thanks much!
    -Lars
