Activity Forums VEGAS Pro adding sun rays
  • John Rofrano
    October 26, 2014 at 10:46 am
    [Tobin Bell] “Is this possible to make the rays in Vegas? If so, would you instruct me please how can I do it?”
    Yes, use the Sony Rays plug-n.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Tobin Bell
    October 26, 2014 at 1:19 pm
    Thanks for the tip John, I meant it’s not that easy because the alpha channeled front picture messes up the ray prints. However I managed to solve this issue by adding a third image of a flat mix of the two involved image and then used the rays plugin with the “Effect only” option.
  • John Rofrano
    October 27, 2014 at 10:42 am
    [Tobin Bell] “I managed to solve this issue by adding a third image of a flat mix of the two involved image and then used the rays plugin with the “Effect only” option.”
    That was a good solution. Sometimes you need to duplicate a track to use as a mask for other tracks. Im glad you figured it out.
    ~jr
