Activity › Forums › Avid Media Composer › Adding subtitles to an edit
  • Adding subtitles to an edit
    Posted by Carlos E. martinez on August 21, 2006 at 1:37 am
    The problem I am facing is new.
    What I want to do is add subtitles to a film of mine. I need to add two languages, which I will author in later on with DVDLab Pro.
    But I have to sync the titles and make the files first.
    I have tried doing that with Subtitle Worksshop and with Subtitle Edit, but I can’t seem to work out how to use them.
    I thought there might be some kind of template to fill with the TC in / TC out and every title, but it doesn’t seem to be so.
    How do you do and what do you use to write a subtitle starting from zero?
    Tito Haggardt replied 20 years, 1 month ago 3 Members · 3 Replies
