Activity › Forums › Adobe Premiere Pro › Adding subtitles to Adobe Premiere Pro with .srt file ready
  • Adding subtitles to Adobe Premiere Pro with .srt file ready
    Posted by Vikkramm Chandirramani on January 11, 2019 at 2:44 pm
    Hello,
    I have a project in Adobe Premiere Pro in DPX format which I’m exporting to Vimeo 1080p video. How do I go about adding subtitles to this? I had created subtitles in .srt format. I’m unable to drag this to a layer above the DPX layer in Adobe Premiere Pro CC 2019. Is this even possible? How do I go about it? I tried importing the .srt into premiere. It shows up in the bottom left corner but I can’t figure out how to proceed beyond that. I tried exporting it as ‘Burn to movie’ but this resulted in the captions showing up against a black background.
    Is there any workaround?
    If I export to Vimeo 1080p and then bring back the ouput file, create a project, drag the srt file as a layer and re-export, will it result in loss of quality?
    I’ll appreciate some guidance. Thank you.
    Vikkramm Chandirramani replied 7 years, 8 months ago 2 Members · 2 Replies
  • Andreas Kiel
    January 11, 2019 at 7:51 pm
    You don’t need to do anything in PPro unless you want to burn in the subtitles – just upload the .srt to Vimeo.
    If you need burned in: import SRT, select the Caption file in the browser and make your settings (including background) there. You can do it for single titles, a selection or all at once.
    Spherico
    https://www.spherico.com/filmtools
    \”He who fights with monsters should be careful lest he thereby
    become a monster. And if thou gaze long into an abyss, the abyss will
    also gaze into thee.\” – Friedrich Nietzsche, Beyond Good and Evil
  • Vikkramm Chandirramani
    January 12, 2019 at 11:38 am
    That doesn’t help. I can place the .srt file above an .mp4 file but not above this DPX sequence. I want to burn the titles to the video. What could be wrong?
