Activity › Forums › Apple Final Cut Pro Legacy › Adding Subtitles to 16:9 (1280X720 HD) Video using Letterbox?
Posted by Bob Tanner on December 9, 2012 at 11:03 pmHow can I letterbox my video without loosing quality and having the subtitles on the letterbox? Thanks!
Nick Meyers replied 13 years, 9 months ago 3 Members · 4 Replies -
Chris Tompkins
December 10, 2012 at 12:35 pmcrop.
Edit in a 1080 sequence.
Edit in a 720×480 Widescreen SD sequence.Chris Tompkins
Video Atlanta LLC -
Bob Tanner
December 10, 2012 at 11:06 pmSorry, I don’t understand what you mean by, “Edit in a 720×480 Widescreen SD sequence.”
If I edit in 1080 sequence and crop, I won’t loose quality, but I’ll cut part of the video which I need…
Chris Tompkins
December 10, 2012 at 11:13 pmIf you have a 1080 sequence and put a 720 video in there, you’ll have plenty of room and black around the edges. Scale up the 720p some and have letterbox, you won’t detect the tiny, tiny quality hit from doing this.
We use 720p footage in 1080 edits a fare bit and no loss for wear.
Just my .2 cents worth.Chris Tompkins
Video Atlanta LLC -
Nick Meyers
December 11, 2012 at 7:44 am“If I edit in 1080 sequence and crop, I won’t loose quality, but I’ll cut part of the video which I need…”
there’s your dilemma.
if you want to CROP your image DOWN to 1920×1080, while maintaining original quality
your mastering format will be some impossible frame size,
some sort of HD 4/3it’s not impossible of course: you can make any frame size you want in FCP,
but you ant get any RT at all, render city.so maybe lock off with subs,
tun the subs off, export,
re-import and put in your mew-fnaglerd frame0size sequence
and add the subs back inwhat’s it for?
nick
