Activity › Forums › Adobe Encore DVD › Adding Subtitles in addition to Closed Captions in Encore CS6
  • Adding Subtitles in addition to Closed Captions in Encore CS6
    Posted by Justin Isbecque on March 5, 2015 at 5:39 am
    I recently submitted a video to a closed captioning service (3play media) and have been able to combine the returned .scc files with my video file in premiere to have an combined output file.
    HOWEVER I am trying to add both Closed Captions and Subtitles in Encore. I was able to attach the .scc file through field 1 in the caption menu, but when I add a subtitle track and try to import a new subtitle file, the program does not allow me to attach the requisite .scc file.
    Is there a different manner in which I should attach the file or is there a separate file type other than .scc that I need to attach?
    Ricky Barrow replied 11 years, 6 months ago 2 Members · 3 Replies
  • Ricky Barrow
    March 6, 2015 at 5:37 pm
    you need a .TXT file – specific to Encore (UTF-8) I believe if memory serves me. The caption company should easily be able to provide this file from the work already done – it should take all of 2 minutes to export the .TXT file then open and save as UTF-8
    Ricky
  • Justin Isbecque
    March 6, 2015 at 5:48 pm
    I have downloaded the plain text file from the company and changed my preferences in text edit to be able to save the file as UTF-8.
    However when trying to import subtitles in encore it still says “invalid line found in subtitle script” for every line in the file.
    Any ideas?
  • Ricky Barrow
    March 6, 2015 at 6:42 pm
    open the .SCC file in something like notepad and see if the numbers are associated with timecode – if they are then you may need to ask for them to ripple the numbers so that the .TXT file begins with 00:00:00:00 – Encore wants to see the “file” start time as opposed to the TC.
    This is a possible solution.
    Ricky
