Activity › Forums › Adobe After Effects › Adding Source Name to a layer as text
Posted by Frederic Lumiere on January 3, 2013 at 1:05 amAnyway to burn the source name to a layer as text without having to add a text layer?
Paul Roper replied 13 years, 8 months ago 3 Members · 2 Replies -
John Cuevas
January 3, 2013 at 2:29 amNot possible, sorry.
Johnny Cuevas, Editor
Thinkck.com“I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
—THOMAS EDISON on inventing the light bulb. -
Paul Roper
January 3, 2013 at 2:10 pmI assume you’ve figured out that if you DO add a text layer, you could just add the expression:
thisComp.layer(index+1).name
to a text layer’s ‘Source Text’ if that text layer is directly above the “source name layer” to display the layer name.– Paul
