Activity Forums Adobe After Effects Expressions Adding selected item in project panel to a comp
  • Dan Ebberts
    August 17, 2013 at 4:09 pm
    Something like this:
    var myComp = app.project.activeItem;
    for(var i = 1; i <= app.project.numItems; i++){
    if ((app.project.item(i) instanceof FootageItem) && app.project.item(i).selected){
    myComp.layers.add(app.project.item(i));
    Dan
  • Shahrokh Jahanzadeh
    August 18, 2013 at 4:39 am
    Thanks Dan.
    this code worked perfectly but there is a new problem…
    your codes worked when we selected Comp panel or timeline panel
    and when I added this new line in top, it didn`t work because the project panel will select.
    app.project.importFileWithDialog();
    How we can fix it?
    Shahrokh
  • Dan Ebberts
    August 18, 2013 at 5:48 am
    Did you try making your new line the second line? If that won’t work for you, I guess you’ll have to go through the project bin and find your comp by name.
    August 18, 2013 at 5:56 am
    Oh my GOD…
    No I didn`t try, I really forgot this one…
    that way worked perfectly
    You are the BEST
    thanks Dan
    Shahrokh
