Activity Forums Maxon Cinema 4D adding segments after the fact?
  • adding segments after the fact?
    Posted by Kelly Johnson on March 2, 2007 at 5:42 pm
    I have a cube that I’ve animated. It shows up as a blue triangle in the Objects Manager. I need to add segments to the Z parameter but I can seem to get to it.
    Do I need to create a new cube at the exact coordinates and just add segments before animating or is there a way to add some segments now?
    I’m using a Shatter deformer on the cube and rotating the Pitch of the cube but that’s all I’ve actually done to the cube object itself.
    Kelly Johnson replied 19 years, 6 months ago 2 Members · 2 Replies
  • Joe Bird
    March 2, 2007 at 6:55 pm
    the blue triangle indicates that it is no longer a parametric object, so you can’t input the segments on the z axis like you did at the beginning. You can use the knife tool to subdivide it on the z axis… or start over with the cube, input the desired segments, etc
  • Kelly Johnson
    March 2, 2007 at 8:20 pm
    ok, thanks!
