Activity › Forums › DaVinci Resolve › Adding RED files to the Browser takes ages
Posted by Ola Haldor voll on July 5, 2011 at 11:05 amI’ve just got a project here. I’m right-clicking to Add folders and subfolders into media pool. Resolve starts working, the beach ball is rotating and it just keeps on spinning for tens of minutes. How long should I wait for it to be done? It’s about 1.2TB worth of material. So I guess it’s rather massive for an 8 minute long gig, but still. I’m hoping I won’t have to buy Storm just for this one.
Mikhail Puzyrev replied 15 years, 1 month ago 9 Members · 21 Replies -
Rohit Gupta
July 5, 2011 at 11:16 amHi Ola,
Do you have all the files in one folder, or sub-folders? Can you try adding a sub-folder at a time just to test.
If you still have issues, could you please capture logs, and email our support. We’ll take a look at the logs.
Rohit
Ola Haldor voll
July 5, 2011 at 11:18 am -
Dan Moran
July 5, 2011 at 11:21 amHey Ola,
Can you just double check your red decode settings ?
Sometimes if my system is a little slow when opening red files it can be due to the red decode settings being set to full premium etc..
It may not help but it’s just something I’ve noticed before!
Dan Moran
DaVinci Application Specialist
Blackmagic Design EMEA -
Sascha Haber
July 5, 2011 at 11:37 amStorm is great, but you also could just log and cut with RedCine X.
I always do that for locked edits.
better to load in 100 gig than 1,5 terra.
But yes, Resolve should just work anyway.A slice of color…
DaVinci 7.1.2 OSX 10.6.7
MacPro 5.1 2x 2,4 24GB
RAID0 8TB eSata 6TB
GTX 285 / GT 120
Extreme 3D+ WAVE -
Ola Haldor voll
July 5, 2011 at 12:14 pmNice one, Dan. That certainly helped. Still got a few folders that takes ages to import.
Gabriele Turchi
July 5, 2011 at 1:10 pmi have loaded 2TB of material on 2 different (2TB each) project on V8 and it took no more than 2 minutes ….
g
Ola Haldor voll
July 5, 2011 at 2:32 pmHmm.. That’s insanely fast.
If the R3D files are spanned into dozens of files, might that slow it down?
Rohit Gupta
July 5, 2011 at 2:43 pmIf the R3D files are truncated for whatever reason, they take a very long to open as the Red SDK needs to scan through the file to detect the length of the clip. Perhaps this could be causing the problem.
Nate Weaver
July 5, 2011 at 5:47 pmOne extremely long take maybe, lots of spanned R3Ds, and the camera crashed, making the ingest scan the entire file?
Wait, Reds don’t crash. Nevermind.
Nate Weaver
Director/D.P., Los Angeles
https://www.nateweaver.net -
Danny Scotting
July 6, 2011 at 1:45 amFrom memory (haven’t done it sine V7). If you add the red files at anything other than full res premium you can’t then change it back to full res.
BMD please correct me if I’m wrong!!You need to add it at Full res then once its in your media pool you can downsize it to half res good for better playback. Just make sure before you render you put it back to Full res premium for best quality output.
