Activity Forums Adobe After Effects Expressions Adding random spikes to wiggle…
  • Adding random spikes to wiggle…
    Posted by Pierpaolo Ferlaino on June 24, 2014 at 7:56 pm
    Hi.
    I’m trying to emulate the Misfire GateWeave plugin (it does not retain my layer’s transparency).
    I used a wiggle expression in the layer’s position and it works quite well but Misfire GateWeave randomly add some spikes (they call it noise frequency) to the wiggling movement making the layer x position suddenly shift and come back in place.
    How can I achieve this?
    Pierpaolo Ferlaino replied 12 years, 2 months ago 2 Members · 2 Replies
  • Dan Ebberts
    June 24, 2014 at 8:37 pm
    Maybe you can tweak this to get something that works:
    amp = 25;
    freq = 2;
    w = wiggle(freq,amp)-value ;
    value + w* (length(w) > .9*amp ? 5 :1)
    Dan
  • Pierpaolo Ferlaino
    June 25, 2014 at 1:42 pm
    Thanks Dan.
    Tweaking your expression did it.
