Activity Forums Apple Final Cut Pro Legacy adding pulldown
  • adding pulldown
    Posted by Eli Mavros on April 29, 2005 at 4:31 pm
    When doing an edit to tape from FCP from a 24p timeline, does FCP automatically add the pulldown back in, or do you have to go through cinema tools? Is it possible to take 24pA footage, do the 2:3:3:2 pulldown removal, edit in 23.98, and then when outputing to tape use a 2:3 rather than a 2:3:3:2? I think the standard pulldown looks smoother than the advanced, plus I will be mastering on digibeta rather than going back to DV (which I think is the only way to do the Advance pulldown). The reason that I am even removing the advanced pulldown, is because I would like to make a 24p DVD too.
    No rush, I am a long way from this step, but better to be prepaired. Thanks.
    -Eli
    Eli Mavros
    Eli Mavros replied 21 years, 4 months ago 1 Member · 0 Replies
  • 0 Replies
