Activity Forums Maxon Cinema 4D Adding plain effector to a cloner with dynamics
  • Adding plain effector to a cloner with dynamics
    Posted by Victor Camacho guerrero on February 10, 2015 at 4:51 pm
    Hello,
    The idea is to create a pile of potatoes ( https://thumbs.dreamstime.com/x/pile-potatoes-14699244.jpg) and they are animated from the bottom , using a plain effector.
    I have a cloner on Object mode, based on a landscape object. The distributon is on Volume. The volume mode is on surface. I can use a plain effector and all good. But they potatoes are intersecting.
    For that I did ( I copy from Creative Cow forum) :
    “* clone onto your object;
    * give the cloner and object mograph rigid body tags;
    * set mograph’s gravity to 0 (under project settings);
    * in the cloner’s rigid body tag, turn on Force>Follow Animation>Position And Rotation.
    When you hit the play button, overlapping objects will separate. Then you can make the cloner editable to keep the clones from moving around.”
    Even If I can have the potatoes not intersecting, I cannot use the plan effector anymore, to bring them back one by one.
    Many thanks!
    Temel Yaşar replied 10 years, 2 months ago 4 Members · 6 Replies
  • Cassius Marques
    February 10, 2015 at 7:11 pm
    When you make it editable, put everything inside a fracture object and it will work with every effector
  • Adam Trachtenberg
    February 11, 2015 at 4:54 am
    You can probably keep your objects in the cloner. You just need to go into the dynamics tag’s Force tab and set “follow position” to a relatively high position (like 10 or higher). That allows mograph to have control over the clone’s position while dynamics still maintains collision detection.
  • Victor Camacho guerrero
    February 12, 2015 at 10:52 am
    Hey guys thanks for the reply.
    Cassius, when I do editable the the cloner, in my case, only leaves one object then put the rest as instances. Weird. Then if I apply it as you said, the Plain effector transition see the whole cloner as one huge block, then it does not animate one by one the objects.
    Adam, I am not sure what you mean, in theory having dynamics stop you to use mograph effectors in the cloners right?
    Many thanks
  • Cassius Marques
    February 12, 2015 at 7:48 pm
    You can either pull them out of the group null or change the fracture’s object mode to “explode segments & connect”
    February 13, 2015 at 9:43 am
    Yes I found the way, awesome,
    many thanks
  • Temel Yaşar
    June 8, 2016 at 5:18 pm
    Thank you. This solved my problem involving using effectors and dynamics together. I could have never guessed this.
