Activity Forums Avid Media Composer adding original audio cut to cut without matchframe?
  • adding original audio cut to cut without matchframe?
    Posted by Armyofrobots on March 20, 2007 at 2:21 pm
    I need to create a cut to cut OMF with all the audio stripped out, and the original audio from the clips cut back in. My current method of doing this is to go to each cut, matchframe it, and then overwrite the audio……. is there a better way, like an easy button, or something? Any help is appreciated. Thanks!
    Armyofrobots replied 19 years, 6 months ago 2 Members · 2 Replies
  • Bouke Vahl
    March 21, 2007 at 8:11 am
    Export to EDL, video only.
    Next, open the EDL in a text editor, change all ‘V’ to ‘A1A2’, re import with reconnecting to media.
    Insert that audio only sequence in your original sequence and you’re done.
    hth
    Bouke
    http://www.videoToolShed.com
    smart tools for video pro’s
  • Armyofrobots
    March 21, 2007 at 5:03 pm
    thank you! I finished this time, but I will no doubt need to do this some time in the future
