Activity Forums Maxon Cinema 4D adding one texture to multiple objects
  • adding one texture to multiple objects
    Posted by Kurt Murphy on April 4, 2007 at 7:52 pm
    How do go about adding one texture to multiple objects. I’m making a cartoon penguin which the body is made up of several objects – when I add a texture to that it adds it to each object individually.
    Also, is there a way to place a shader on an object for the cool texture ALONG a material to add different colors? The shaders don’t have a place to add an image map.
    thanks,
    kurt murphy
    Jan Vork replied 12 years ago 4 Members · 3 Replies
  • Nicholas Toth
    April 5, 2007 at 12:30 am
    right click on the tag and apply tag to children
    Nicholas Toth
    Freelance Animator
    nicholastoth.com
  • Robert P
    April 6, 2007 at 3:53 pm
    or you can place all of your objects into a null object, then put the texture on that.
  • Jan Vork
    August 13, 2014 at 10:26 am
    If, for some reason, a Null Object is not suitable, you can open the Material Editor and drag the selection to the Assignment field. (The lowest option in the Channel list on the left)
    http://www.jaydude.nl
