Activity Forums Avid Media Composer Adding numbers to source/record with MacBook Pro generates error
  • Adding numbers to source/record with MacBook Pro generates error
    Posted by Wendy Rosen on March 3, 2012 at 6:10 pm
    I working on Avid MC 6.0.1
    When I type “CTL, CTL” a number entry window pops up in either record or source monitor. That’s good.
    The problem is that I can’t use the + sign to add positive numbers. When I do this, I get an error sound and nothing happens. Using the minus sign works fine, and the marker moves backwards.
    I don’t have anything mapped to the plus key. Does anyone have any suggestions?
    Wendy
    Jeff Greenberg replied 14 years, 6 months ago 3 Members · 4 Replies
  • Jeff Greenberg
    March 4, 2012 at 3:44 pm
    Nope, broken here too.
    Best,
    Jeff G
    Certified Master Trainer | Adobe, Apple, Avid
    You should follow me (filmgeek) on twitter. I promise to be nice.
    My book (with Richard Harrington and Robbie Carman)- An Editor’s Guide to Adobe Premiere Pro
    Lynda.com – Compressor Essentials 3.5 and 4
    Contact me through my Website
  • Wendy Rosen
    March 4, 2012 at 8:04 pm
    Hi Jeff,
    So do you think Avid is aware of this? I assume it is a bug with MC 6.0.1 when using the 15 inch MacBook Pro.
    I’m also not able to add keyframes to audio tracks, and I’ve got clip gain and volume checked, and I’ve got the keyframe icon activated in the timeline window. Have you had any trouble with that, or is it just me?
    Wendy
  • Drew Reynolds
    March 4, 2012 at 9:36 pm
    I also can’t type the + sign on my 17″ MacBook Pro, MC6.0.1 – it was the same on MC6. But I can type it on the number pad of an external keyboard – but again not on the main keyboard. Very odd.
    I don’t have a problem with adding audio keyframes. You have selected your tracks I assume.
  • Jeff Greenberg
    March 4, 2012 at 11:54 pm
    No, those work fine – could you have the “per track” settings wrong (in the timeline fast menu/audio?) Make sure the track is active (live) too.
    As for the 2x control key, I think they know (or they do now!)
    Best,
    Jeff G
