Activity Forums Apple Final Cut Pro Legacy Adding multiple dissolves of the same length to your sequence
  • Adding multiple dissolves of the same length to your sequence
    Posted by Lee Burrows on June 23, 2006 at 12:21 am
    Hi. I have a ten long sequence with 50 different clips strung out cut together and I want to add a one second dissolve between all of them, is it possible to do all at once in one step or do I have to individually go between my sequence and effects folder and drag each dissolve in one at a time to add them?
    Thanks for any help in advance.
    Tough loss for the US today:( South Africa in 2010!!!
    G5 Mac OS X
    Dual 2.0 GHz
    FCP 4.5 HD
    XServe Raid 1 Terabyte
    G5 Mac OS X
    Dual 2.3 GHz
    FCP 5.02 Studio
    G-Tech G Raid 500 GBs
    2 – Lacie Drives 200 GBs
    Lee Burrows replied 20 years, 3 months ago 2 Members · 2 Replies
  • Bouncing Account needs new email address
    June 23, 2006 at 12:39 am
    To add Multiple Transitions:
    Create the transition you want and make it your “Default Transition”.
    (You can change the default by control clicking on it in the fx tab.)
    Range Select (Select All of) your clips on the timeline (ON THE TIMELINE).
    Drag this selection (yes, the TIMELINE selection) (drag ITSELF back) into the Canvas
  • Lee Burrows
    June 23, 2006 at 2:57 am
    Perfect. Thanks so much, Matte. It was so quick too.
