Activity Forums Apple Final Cut Pro Legacy Adding movement to photos
  • Adding movement to photos
    Posted by Faithf on July 31, 2007 at 7:24 pm
    I have a Final Cut Express and I’ve studied the manual on how to use keyframes to add movement to photos. But I am having so much trouble — literally, I’ve been tackling this for several hours now — that I thought I’d ask for some advice. Is there an easy way to add movement to photos, in particular adding “ease in/ease out” motion to the beginning and end of the move?
    Please, any help or guidance is greatly appreciated.
    Faith
    Stace Carter replied 19 years, 1 month ago 6 Members · 5 Replies
  • Chris Poisson
    July 31, 2007 at 7:50 pm
    Faith,
    FCE has keyframes now? If they work the same as FCP, you do the ease in with the control key and mouse in the canvas. But, be forewarned, keyframing in FC anything is really awful.
    If you just need to animate some stills, take a look at Fotomagico from Boinx. You can learn it in about a half hour, it is really fast and fun.
  • Jeremy Garchow
    July 31, 2007 at 7:54 pm
    FInal CUt is not real great at easing. It can do it if you have image+wireframe selected in your canvas and then you control-click on the stop point and choose ease, but your results may vary and it is not very easily manipulated or implemented in FInal Cut.
    Jeremy
  • Buz Minow
    July 31, 2007 at 10:25 pm
    I agree Fotomgico is nice
    Buz
  • Bret Williams
    July 31, 2007 at 11:46 pm
    Right click on the keyframe in the motion tab in FCP. Choose smooth. Don’t know if it’s the same in FCE.
    I hardly ever bother. Usually find a way to dissolve them in or out while still moving.
  • Stace Carter
    August 1, 2007 at 1:58 pm
    https://www.lqgraphics.com/phototomovie.php
    This is a nice, cheap and easy app that does all that work for you, has plenty of customization options but honestly I don’t use them. I just import my audio for synch, tweak durations and let ‘er rip.
    This has saved me more time than I could possibly measure.
    Cheers,
    Stace
    https://podsquadhq.blogspot.com/
