Activity › Forums › Apple Final Cut Pro › Adding .mov file to Generator
Posted by Martin Gardiner on July 13, 2015 at 3:28 pmHello
We’re using Final Cut Pro and would like to add a couple .mov files to ‘Generator’… can we do this without using Motion? We don’t have Motion.
Martin Gardiner replied 11 years, 2 months ago 3 Members · 7 Replies -
Noah Kadner
July 13, 2015 at 7:17 pmCan you be a little more specific? You cannot edit Motion effects/filters directly without a copy of Motion.
Noah
FCPWORKS – FCPX Workflow
Call Box Training -
Martin Gardiner
July 13, 2015 at 7:30 pmHopefully, I can be more specific, but I don’t know Final Cut. We have a lower third that animates on and then the end of it is loopable. So, one editor who no longer works here brought it into Motion and made one file that is the whole thing, the other file cuts off the beg. animation so that it can be looped. Hopefully, that makes sense.
So, the workflow used to be just to grab the two files from the Generator. Now, we have a new lower third and would like to set up the same workflow for Editors using Final Cut (without Motion).
Can we do this without motion or is it best to just import the two files each time?
Noah Kadner
July 13, 2015 at 7:48 pmEditing the template requires Motion and at $49 seems like a wise investment here. Otherwise you’d need to make a workaround like you described.
Noah
Call Box Training -
Martin Gardiner
July 13, 2015 at 10:09 pmIt’s no longer a template… the new one is just a lower third .mov file made externally. But I guess to get files in the generator tab it needs to be done in Motion?
You can’t just put files in the ‘generator’ tab that will always show up whenever one edits in Final Cut… or can you?
Noah Kadner
July 13, 2015 at 10:46 pm -
David Hudson
July 15, 2015 at 3:22 pmhmm..? Not sure why you are trying to place it in the generator cat?
Are there parameters that need/can be adjusted? If not, you just need the
.mov file in a location all editors can access then place in their event to use as
needed. -
Martin Gardiner
July 15, 2015 at 3:27 pmdo you mean… just in a shared drive that they can just import into the project each time? or is there a spot to put it in like a final cut ‘preset’ or ‘templates’ folder that will always be there every time they open FCP?
I think they’re just used to it being in there, but if that’s no longer an option… I’ll tell them that. thanks
